1199 1199s Master Cylinder Replacement / Upgrade
Discussion in 'Panigale' started by Simon Evans, Aug 21, 2024.
  1. For the last three years I've been plagued with losing front brake pressure if the bike is left standing for a few days. A simple bleed resolves the issue but I am getting tired of doing this before every ride. I know there was a recall regarding this issue but that doesn't apply to my bike even though the symptoms are identical. Can anyone recommend a simple plug and play master cylinder upgrade they would recommend. I have nice, made in Italy, folding short levers I'd like to retain if possible as well.
    Please if you know specific parts numbers that would be golden.
  2. is it worth replacing like for like? rather then going down the road of an RCS version that my require new lever etc?
    I picked up a second hand clutch master without level for 80 bucs online, maybe an option?
  3. My only concern with that approach is the potential for the issue to occur again.
  4. RCS17 or corsacorta come with a lever. But it will likely require switchgear on rhs, from jet prime etc.
