1199s Rear Linkage
Discussion in 'Ducati General Discussion' started by Gary McDonald, Dec 25, 2020.
  1. Been reading up on this. Not had the bike long and mine is set in the F position. My question is for road and maybe occasion track use would I be better setting this in the P position o_O
  2. not made any change to my 1199 link settings, but I have installed the adjustable swingarm pivot to match the 1299 improved geometry.
    if you describe any issues you may have, then we might be able to give you some more input etc
    if its too hard on the rear, then fist check the settings as per standard, and also consider the rear spring preload
