My 1299s got damaged in transport to the track . Where the white clip on the Wire that plugs into the suspension broke slightly . The lever bit that clicks and secures it in had snapped off. I’ve got it back in and working secured with cable ties but need to replace the the white clip. Does any one know where I can purchase just the white clip and if it’s a simple or different repair ?
can you take a picture of the offending part? i replaced about 5 plugs an sockets from my 1199s https://mcet.de/eshop/en/Electric/Ducati-wiring-connectors
https://mcet.de/eshop/en/electric/ducati-wiring-connectors/ducati-1199-connector-set-can-bus-4 fork leg plug (first one i bought from ebay, but Mcet was cheaper)
Thankyou !!!! Thank you so much! That’s everything I need as both top and bottom broke. Can you tell me how you take the old broken plug out of the fork ?
i only replaced the loom plugs to be honest, as this was what was needed on my bike. to de-pin the plug i used a pair of snips on the plastic housing to free all the pins and then slid them including the grommet into the new part.
