Featured For Sale 2002 748r - Fresh Desmo Service & Mot
Discussion in 'Ducati Bikes For Sale' started by TelRobinson, May 8, 2026.
  1. Unfortunately it’s time to sell my 2002 748R.
    I have owned the bike for 6 years and due to a back injury, I haven’t been able to ride it. I don't 'need' to sell, but would rather it sold than sat in my garage.
    The bike has had an extensive amount of money spent on it in my ownership, including a full engine rebuild by Mike at BBS Motorcycles, full paint by Mike at Rage Designs and very recent Desmo service by the amazing team at Pro Team Italia.
    The bike rides like an absolute dream and is just taking up space in the garage. It does an amazing job as an eye candy ornament, but it would be better going to be used and enjoyed by an enthusiast.
    The bike is kept on a Optimate trickle charger and it starts on the button every time. It’s also kept on paddock stands to stop the tyres from squaring off.
    I am 5 minutes from J4 of the M25 in Kent.
    I'm away until Thursday 14th May, so I will update the ad with better photos when I get home.
    2002 748R - £13,500
    • No.0206
    • MOT 06/05/2027
    • 24,126 miles
    • London ULEZ Exempt
    • Ducati Original tool kit
    • 7 Previous owners
    • 2 x Ducati Key
    • Full Ducati book pack
    • Extensive receipts folder with many (not all) parts purchases, old MOT’s, some tax discs and maintenance invoices
    • OEM Ducati rear paddock stand
    • ProBike rear paddock stand
    • Fully painted in 2024 by Mike @ Rage Designs (Warrington)
    • Full Desmo Service at Pro Team Italia May 2026 (all fluids, valve clearances, belts etc)
    • All new brake pads April 2026 - Pro Team Italia
    • Bike has been garaged for the duration of my ownership and kept on paddock stands
    SPEC
    Speed Carbon - Carbon Fibre mudguard
    Speed Carbon - Carbon fibre slab side fairings
    Speed Carbon - Carbon fibre belly pan
    Speed Carbon - Carbon fibre 998 seat unit
    Ducati Performance - Fairing V Panel
    ATR - Carbon fibre upper Airbox with new seals and removable side panels
    Termignoni 45-50mm exhaust collector
    Termignoni 50mm fully refurbished carbon fibre exhaust cans
    Eprom to suit 50mm cans
    Michelin 2 CT’s - 0 Miles
    Tecnosel Mono Seat pad
    Braided fuel hoses throughout
    Ohlins steering damper
    Ohlins Forks - 2025 Serviced by MCT
    Ohlins rear shock - Serviced by MCT and set for 100kg rider
    New OEM Brembo discs
    NOS Ducati front loom
    NOS Ducati main loom
    Carbon fibre swingarm cover
    New clear braided brake lines - 0 Miles
    New OEM Ducati clear screen
    Exact Start Heavy duty starter leads
    1098R Clutch slave
    New OEM Ducati chain guard
    Full set black Roose Motorsport silicone hoses
    Ti RS belly pan brackets
    Triumph Mosfet Reg/Rec Unit
    Metal Quick release fuel fittings
    Metal fuel pump nut
    Renthal 520 Kit - 0 Miles
    • New Renthal rear sprocket - 0 Miles
    • New Renthal rear sprocket carrier - 0 Miles
    • New Cush drives - 0 Miles
    • New Renthal front sprocket - 0 Miles
    Ducabike Black Dry Clutch Pressure Plate - 0 Miles
    Ducabike black clutch spring collars and springs - 0 Miles
    New Yuasa YT12B-BS battery
    GDH Motorsport Carbon Fibre Weighted Brake Lever Guard
    Ducati under seat tool kit
    1098 side stand
    New Ducati air filters - 0 Miles
    Wheels refurbed in black in 2025 - 0 Miles
    New front wheel bearings in 2025 - 0 Miles
    New Ducati handlebar grips - 0 Miles
    New Ducati throttle slide - 0 Miles
    New Ducati speedo cable - 0 Miles
    New Ducati accelerator cable - 0 Miles
    Major mechanical works carried out
    In May 2019 the horizontal belt tensioner stud failed resulting in 2 bent exhaust valves. All 4 valves were replaced with genuine Ducati Ti items and for peace of mind, the Titanium Pankl rods were sent away for X-ray (no issues). Whilst away, these were shot peened at the same time and the engine was given an in-depth inspection to check for wear/issues while it was apart..
    All main bearings were changed during these works, belts replaced, valve clearances set and full service carried out by Mike at BBS (Kent).
    Work carried out by Mike @ BBS Motorcycles in Bean, Kent. All genuine Ducati parts supplied by Motorapido.
    New Ducati Clutch plates
    4 x new valves (horizontal head)
    Rods x-rayed and shot peened
    All new piston rings
    New belts
    New tensioner & idler pulleys and bearings
    New Crank bearings
    New champion plugs
    All new gaskets
    New Oil pressure switch
    Valve clearances set
    Oil filter
    10w/40 Fully synthetic oil (for running in)
    These works totalled £2700
    #1 TelRobinson, May 8, 2026
    • Like Like x 11
    • Lock Thread Lock Thread x 1
  2. Are there two Gear Shift levers ?
  3. I’ve just noticed the 2 different ones in the photos! Good spot!
    I did have DP rear sets fitted with the DP lever, but changed it back to standard now
  4. perhaps you were checking the position for fit... I guessed either that or some very janky AI.. lol Good luck with the sale
  5. Thanks mate!
    That sounds more plausible :laughing:
    The bike is coming back from its Desmo service at Pro Team Italia next week, so I’ll get some fresh photos when it’s back.
  6. Hello - is this still available?
    Thank you
  7. Hi Mark, I’ve just replied on the Profile message.
  8. Thanks Tel! That's amazing news. Now, all I need to do is find the message. Bear with me mate :)
