2024 Charger Recommendations Please
Discussion in 'Streetfighter' started by Paulos, Oct 12, 2024.
  1. Hey all, its getting to that time of year (UK) where the bike sits in the garage for ages:cold_sweat:
    Anyone recommend a specific charger for the '24 V4S?
    Is it just a case of getting an optimate and connecting straight to the battery as per usual, or are there any other Ducati-isms I need to know about:grinning:
    Any advice appreciated!
  2. 1 vote for Noco here.
    I use them on all my bikes. work great with lithium or traditional LA cells
  3. Cheers for the reply,
    I was just looking at the Noco Genius 5 following your suggestion and it states a charge rate of 4-10 amps, yet the Bike manual says only to go for a max of 1.5
    Does that sound right, or am I looking at the wrong thing?
  4. I use an Optimate Duo. No issues over 3 winters.
  5. Crocodile clips for a straight hook-up, it also has another connector which you wire to the battery, then that has a plug which the charger plugs to (should also have a weatherproof cap) - that should see you right.
    I believe the Duo (as the name suggests does lead acid and Li:
    https://www.optimate.co.uk/battery-chargers/optimate-1-duo/
    BUT - I have a 1098 and a 1200 XE Scambler, both the Lead batteries - hopefully someoine with a V4 will come along and help you find the right (best) one.
  6. I use the Genius 2 and Genius2x2. Never had any issues and can recommend them. The 5 is for larger batteries... Not needed for bikes
