748 Cutting Out
Discussion in 'Technical Help' started by higgy748, Oct 11, 2025.
  1. I had a ride down the EastYorks coast from Skipsea through Hornsea, Aldborough to Withersea where i had a Bacon and Egg butty.
    It's a superb bendy road. On the way back came out of a 90° bend accelerated and the bike cut out. Pulled in the clutch and coasted to a stop. There were no lights on the dash. It should have had generator and oil showing and neutral when I stopped.
    I turned the key off and then back on and everything lit up and it started. Rode home with no more problems.
    Yesterday I went in the garage put the key in and turned it on and nothing I was about to turn it off and the lights came on and it started. After that I turned it on and off a few times and it was OK.
    Im thinking that the power relay down by the battery is sticking and on its way out
    Anyone had similar problems
  2. I had the main (yellow) relay fail intermittently, when it goes everything just switches off - sounds like your problem might be the same.
    You can get an original from Ducati or a compatible for much less but be aware it is a slightly different variant of relay from the norm so your local motor factor might not stock it. Although it is a standard 5-pin design it has 2 NO (87) contacts rather than NO (87) & NC (87a) 'changeover' contacts.
    I found a replacement on ebay for just a few £. My advice, buy 2 so you have a spare plus, if you have multiple (older) Ducatis they all use the same part.
  3. it should be easier than usual to find because of the total power loss symptom - i've known car and motorcycle battery main terminal connectors to go open-circuit and present like this.
    Isn't there a big 35amp fuse in a seperate holder somewhere on these also? - would probably be light corrosion in this case.
  4. Ive cleaned all the earth's and checked the fuse. Ive ordered the relay from Ducati Mondo, I was aware of the relays difference.
    I will be nicking the relay from the MV till the new one arrives.
    Had it running today and nothing untoward.
