Is there something special about the Ducati one? Prepping for the MoT and the indicators are a bit intermittent with a loud buzzing from one of the relays. I trace it to the ignition relay, looks like a normal 5 pin so it's replaced. Then nothing at all. Put the old one back in and it's working. I check pins 30 and 87a, no connection on the old one but connected on the new one. 87 and 87a connected on the old one but not the new one. The internet says that the new one is as it should be, but it doesn't work in the bike so I am confused Any help would be great, thanks Editted to add, that I know the indicators have a separate relay, but it was the ignition relay making the noise and the wiring diagram doesn't show 87a but there are 5 wires...
Has been discussed on the forum in the past. The relay must have twin 87 outputs. https://www.ducatiforum.co.uk/threads/yellow-relay-916-supersport-etc.86084/#post-1847207 4RA 933 791-161 is known to work. https://ebay.io/m/VplY9R
