750ss Jetting Question...
Discussion in 'Technical Help' started by Loz_stone, Jul 26, 2016.
  1. I assume the OP knows to tune from the top down? That is:
    First make sure each carb is in good condition, o rings, float levels, gaskets, carb to cylinder rubber if it has them.
    Select the main jet to best suit your set up and select the jet that produces a good plug colours, this will be checked when you pull each plug after a full throttle run.
    Once happy tune the needle height and shape.
    Then and only then tune the lower circuit.
    Carbs are a pain to get right but once corrected way nicer than injection systems. Your carbs will not be the same as somebody else and without a methodical approach you are pissing in the wind to be frank. Either this or go to dyno so they can set it with afr read in real time.
    Good luck.
