848 848 Evo Into 848
Discussion in '848 / 1098 / 1198' started by trialnick, Jun 12, 2018.
  1. Can anyone tell me the complications of fitting a 2012 Evo engine to a 2009 848
    Thanks in advance
  2. Is there any point? Aren't they the same?
    Chuck an 1198 in there!
  3. ah, makes sense now. not knowledgeable enough to contribute beyond that, but good luck in getting the motor in and the bike up and running.
  4. Yes my 848 engine went bang so looking for options. A 2012 evo engine came up locally hence the question. If it has a few more horses great but not the decider
  5. The throttle bodies are different - bigger.
    The ecu will be different - yours can be reflashed to suit.
  6. Pin outs on ECU differ. Pin outs on dash need to be compared.
  7. Why does the ECU need changing, or clocks, with a simple engine swap? TBs sound like they may need a bit more effort.
  8. again though he could just use his existing tbs and rubber holders...
  9. The evo TBs are bigger (same as 1098) yup, could use original TB's and rubbers,or maybe engine seller has evo TB's? ECU is programmed different, not just fueling, pin out is different (starter circuit IIRC).
  10. you could even put a 1098 or 1198 engine in there ....let alone a whatever 848 motor... as long as its alongside
    original loom
    original dash
    original ecu
    original tbs
    with a dyno set up .
  11. 848 evo engine
    1098/848 evo tb
    848 loom
    848 dash
    848 ecu in 848 config with 848 evo map
