848 848 Evo Led/micro/sexy Indicators?
Discussion in '848 / 1098 / 1198' started by dubcat, Jul 14, 2018.
  1. The massive indicators on the back of my 848 Evo do not go well with such a sexy rear end. I’d like to replace those indicators with small/sexy little ones. Can anyone point me in the right direction?
  2. I replaced mine with Kellerman Trapezoids, almost anything will work, but I replaced the 1098 standard tail piece with a Melotti Tail tidy.
    R&G also do a cheaper tail tidy, I think Rizoma did a tail tidy too but like everything Rizoma that will be big bucks for what you get.
    I don't know of anything that will bolt onto the OEM number plate holder
    Mine worked fine with no issue on flash rate, providing the standard front mirrors/indicators were used, but when I went to DP mirrors which have a different number of LEDs the flash rate with the ignition on and engine off, is a good deal faster; with the engine running the flash rate is correct.
    Tried to correct this with resistors but it made no difference
  3. Just a word of warning on the Brakers (it it is still available).
    Construction Regs dictate that indicators need to be certain distance from the center line of the vehicle, I can't remember the figure, but if I recall correctly using the vents, is below the minimum
    I know this is not a biggie, but if you have a particularly zealous MOT tester, you could have issues.
    You'd need to be particularly unlucky but just making you aware
  4. I thought we went through all that when Brian first introduced them, and they were fine. My MOT tester certainly said they were, i forget the rule he quoted but they passed.
  5. @Pavey looking up the regs it looks like they need to be a minimum distance of 240mm so that's a little under 10 inches.
    I've just checked and you're right, If you measure from the far end of each, vent to vent it exceeds that easily
    Apologies I was probably getting mixed up with the type that flashed either side of the stop light
    Duff info on my part
