848Evo Main Bearing gone
Discussion in '848 / 1098 / 1198' started by Fire_2, Sep 16, 2013.
  1. See if there is any lateral movement by pulling the flywheel up and down, any movement could be the sign of a bearing either going or having already gone if it is fairly obvious movement. Here's a link to cheap bearings that are OEM I have also posted this on a separate thread as there are a couple of posts covering this very problem at the moment. You can see the saving compared to what I paid as part of my rebuild.
    Quote:
    Ducati Main Bearings Should fit 748-Onwards. See link.
    You might find this link of interest £65 for both bearings.
    Below is an extract from my invoice for my engine rebuild you can see the comparative Ducati prices.
    Special Offers
    [TABLE="class: cms_table_cms_table, width: 603"]
    [TR]
    [TD]Ducati big end shell[/TD]
    [TD]4[/TD]
    [TD]22.23[/TD]
    [TD]88.92[/TD]
    [/TR]
    [TR]
    [TD]Ducati main bearing LH[/TD]
    [TD]1[/TD]
    [TD]57.28[/TD]
    [TD]57.28[/TD]
    [/TR]
    [TR]
    [TD]Ducati main bearing sleeve LH[/TD]
    [TD]1[/TD]
    [TD]37.49[/TD]
    [TD]37.49[/TD]
    [/TR]
    [TR]
    [TD]Ducati main bearing RH[/TD]
    [TD]1[/TD]
    [TD]62.22[/TD]
    [TD]62.22[/TD]
    [/TR]
    [TR]
    [TD]Ducati main bearing shim[/TD]
    [TD]2[/TD]
    [TD]13.16[/TD]
    [TD]26.32[/TD]
    [/TR]
    [/TABLE]
  2. Just get out and ride and enjoy your bikes. Shit happens in life sometimes.
    With the number of bikes out there, you will get some failures but equally its a long way from being a very common occurrence.
    One thing i was told a long time ago was never to let an engine labour in too high a gear which is too easy to do on a torquey twin.
    Its supposedly not good for the main bearings.
