900 Supersport - 1992 - Misfire Diagnosis...?
Discussion in 'Supersport (1974-2007)' started by DucatiChappie, Jul 13, 2025.
  1. Could this be some kind of breather issue? Some piping in the fuel tank? (I don't know much about carbed 900s). I've had similar issues on FI bikes that have been solved by cleaning up the fuel filler cap. But I am no mechanic, sorry if I'm talking rubbish.
  2. Don't know about the SS but, on Monsters with the same engine and carbs, there are some little plastic pods that the carbs vent into.
    I believe the function is to protect the carbs venting from airflow, causing pressurisation issues, not sure how critical this is or whether the SS has a different setup but maybe it's something related to this, especially if it only happens on the move?
  3. The breather issue is relatively easy to diagnose and fix. If the tank can’t breathe, because the breather holes in the cap are blocked, the effect will be that fuel being pumped out of the tank to the carbs will create a vacuum in the tank, starving the supply of fuel. If this is what is happening, try and open the cap. It should be difficult to do so as the vacuum will be ‘sucking’ the cap closed. If this is the case, simply clear the breather holes in the cap, the collar below the cap and at the breather/overflow nozzle at the top/front of the tank. There were tales of some tanks imploding due to this vacuum, but they may have been urban myths.
  4. Hmm, well OK. Firstly, thank you for all your replies while I've been doing other stuff over the past week.
    I have had another crack at it just now and am fairly confident that it isn't a sticky float. To test I checked the drain on both carbs to see whether there was fuel in the float bowls and there was. Then I ran it down the road. It started up fine as normal, running on both. A couple of hundred meters down the road and the misfire is still there under load. Took it back home and checked the drain on the RH (front/horizontal) carb bowl and there was still fuel in it, so I don't think that's the cause.
    I doubt it's tank vacuum as that would affect both carbs/cylinders, rather than just the one, but it's a good thought.
    @Dukedesmo - good shout on the carb breathers - you are right the SS does have the plastic pods and, guess what, one of the breather hoses had popped out and was lying on top of the engine cases. Sadly though, it was the one for the vertical cylinder, not the horizontal, so its not that either. I've put it back in now.
    I'm now at the point of trying all things again. I will replace the HT leads I think to eliminate them as a cause (BTW - is there any difference in HT lead quality? You can pay £2.99 inc postage or £15 pus postage for a 1m length of HT wiring on eBay, seemingly both the same spec: 7 mm O/D, 21 core, 0.3mm, 1.5 mm2 cross section. Don't want to buy absolute dross, but also don't want to get ripped off by confusing price with quality, if it's all the same stuff!).
    For the time being I have popped the CA coil back on the the horizontal cylinder and taken it for a run. It's still lumpy and misfiring, but seemingly not as bad as it was previously. The front pipe was good and hot when I brought it back.
    Have also been on a charm offensive with the neighbours, so now they sympathise with my issue, rather than just thinking I'm a noisy hooligan disrupting their peace. At least I hope they do. They've stopped scowling at me anyway. Putting the standard cans back on instead of the carbon Microns while I worked through it all was probably a smart move...
    Cheers
  5. If it's a harsh cutting out i would point somewhere (again) at the ignition system, if its softer or gradual then i would be looking at the fuel side.
  6. Yeah, I think I agree. The fact that it is OK on start up and tickover but struggles under load suggests fuel.
    The carbs have been cleaned but I guess there could still be some rogue gunk in there. Going to have to get them out again and have a proper look.
  7. Any update on wether you have sorted your problem?
  8. Hi, no sorry for the silence. Not solved it yet as life has got in the way slightly, but hope to get back to it soon. I have pulled the carbs back out now and going to have a good look through them. They have been ultrasonically cleaned and inspected before being rebuilt and I was assured that all was fine, but I will have another look though to check whether I might have a sticky float or a big of rogue dirt blocking a jet that might have been missed.
    If it's not that then I'm not sure where next...
  9. Thanks . Mine has started to do virtually the same . I had new high capacity coils fitted in April and its been spot on, done about 900 miles . It now starts on two, ticks over for 30 seconds and goes onto one cylinder . The front plug is soaked . Put a new plug straight in and it makes no difference, still only running on the rear cyclinder . It's booked into my local Ducati indepandant to look at it on 17th November, I booked it in mid-october but this is the first avalability they have so the riding on it for this year is done . I hope they can sort it . I know nothing about carbs , but surely it must be a sticking float or jet ?
  10. if front plug is soaked, then it sounds more like lack of a spark? immediately it goes onto one cylinder, have you tried resting a spark plug on the cylinder head and starting it to check for a spark?, preferably at dusk/dark as makes it much easier to see. You don't need to take the plug out, just use a slave plug.
  11. I have looked at the sparks and they don't seem that big or bright considering the new CCS high capacity coils. I think I looked at the spark when they were fitted and was impressed by the size and colour, I can't really remember. Perhaps I'll have a fiddle later on this afternoon.
  12. It looks like a very weak spark on both cyclinders . When you hold the start button it's a weak spark which after a few seconds looks like it fades out to virtually nothing .
  13. All sorted now. A new pair of CDI units fitted by the local Ducati specialist. She's on the button again . Roll on spring
  14. excellent news, the ones that failed didn't happen to have an odd bit of straight aluminium strip about 1/8 of an inch sticking out of the resin did they?
  15. Sorry I've no idea . My dad picked the bike up for me and I've not seen the old ones as i didn't see the point in having them back if they were kaput!
