'93 900 Superlight Starter Won't Crank
Discussion in 'Supersport (1974-2007)' started by Kitjv, Jun 20, 2025.
  1. Interesting thought. I assume that the 2 relays are virtually identical. Thank you.
  2. A few years ago, when cranking the engine, gas (petro) spewed out of the crankcase breather like a volcano. The cylinders were not hyro-locked, but the crankcase filled with gas. Subsequently, I installed a shut-off lever on the fuel line from the tank to the carbs. Now whenever I finish riding I turn off the lever.
  3. If indeed the problem is the starter motor itself, it sounds like I have 2 options: (1) replace the starter motor with a new one or (2) rebuild the current one. For those of you who have experienced a defective starter motor, is the cost of a new one worth the time & effort of a rebuild? Thank you.
  4. Mine just needed new brushes (to replace the corroded 12v stud ) the commutator was ok , if this is worn or the windings in the starter are broken then new is probably better. You won’t know which is which until the starter is examined. You don’t say what mileage the bike has ? This may help armchair enthusiasts more ie higher miles likely means more wear
  5. The engine has 16,500 miles which is obviously low for a 32 year-old bike. Also, it has always been garaged & virtually never ridden in wet weather (I live in area of the west coast of the U.S. with little rainfall).
  6. That doesn’t sound high enough for wear & tear problems on the starter , mine was over 30k miles when I replaced the brushes. Probably best pulling it out of the crank case if you’ve verified you can rotate the engine ok ie it’s not locked up. You can then bench test the starter with jumpleads & a battery to see if it spins without load & get easier access to the brushes /commutator to eyeball them for issues, measure windings for breaks /resistance checks or take it to an auto electrician to check it.
  7. Although the fuel pump setup shouldn't allow it to, there is a chance that fuel could feed back to the carbs when stopped on my Monster and therefore if the carb float valves leaked it could lead to this situation plus, having split-single carbs, the downdraft carb to the horizontal cylinder would overflow directly into the cylinder.
    I didn't want a manual shut-off valve as I'd likely forget to use it therefore negating any benefit so, I fitted an electric fuel shut-off valve to the fuel line. It opens when powered by the ignition and in the event of failure it has a manual open lever to be able to run the bike.
  8. Agreed, my 916 has 54,000 miles on it with the original starter motor and never had any bother with it (or the solenoid).
    Luck of course plays into it and failures can happen earlier but seems unlikely at 16,500 miles.
  9. Ive just done a starter on a hyper with relatively low mileage so they can fail. Motor was very stiff to turn when removed.
  10. The bushes are straightforward enough to swap out and cost a fair bit less than a new starter
  11. I will check my options. Any recommendations on a good, online parts supplier of Ducati parts?
  12. In general Stein-Dinse is the 'go-to'. :upyeah:
  13. Your info says Oregon, so it might be good to ask the 'parts supplier' question on the US forum. I expect that (the excellent) Stein-Dinse parts could be a bit expensive for you, especially nowadays.
  14. Actually shipping to the U.S. from "across the pond" is generally not that expensive. I noted that there are several aftermarket starters available. I would really appreciate the recommendations from those of you who have had experience with these options. Thank you so much
  15. Id use Electrex World in the UK, they do starters, and the bushes.
    However, do Nichols not do one in the US?
  16. Thank you for the suggestion. I contacted ElectrexWorld to verify that they have a starter that will fit my Superlight. Also, I sent an inquiry to Nichols here in the U.S.
  17. Did you test the relay?
  18. Yes. I first verified the "click" in the relay when the starter button was pushed. Next, I connected a voltmeter to the (removed) positive cable on the starter & to ground on the engine. With the ignition on & the starter button pressed, the voltage read 13.7V. Finally, I connected a a jumper cable between the battery positive terminal & the positive terminal on the starter . Also, I connected a jumper cable from the battery negative terminal to starter motor case (negative). Thus, I bypassed the relay entirely. Still the engine would not turn over. Thus, it seems like the problem lies in the starter motor.
  19. Thank you for the info. I plan to remove the starter & bench test it. If the starter is indeed bad, I will disassemble it. However, my gut feeling at this time will be to buy a new starter. I believe that they are still out of stock at ElectrexWorld. However, Rick's Motorsport Electrics here in the States sells a starter that appears to be top quality. In fact, the largest Ducati dealer here on the West Coast sells that starter (since the OEM starter is stupidly expensive).
