Hi All, Anyone has done a dyno time for their 2005 999\999s pc3 map build? Can you share a map if you have below setup. 2005 and up 999/999s. Full 57mm termignoni system, DP ecu and DP air filter. PM me if you have one.
I fairly recently had mine on a dyno and tried a few different maps, I found that because of the age and lack of use none of the maps were very close. I ended up just doing a specific fuel mapping just for mine, Definitely worth it. The difference in AFR through the range from first run to last as great, 3-7 hp picked up everywhere. Beauty of power commanders! I was also told on a separate issue with my ECU that even though it said 'performance' on the ECU sticker the actual firmware was standard!
