I had a michelin manual footpump, which worked well, but the frame fatigued and broke ( seems common problem on google search). An older version of a battery powered Ryobi pump didn’t last long. ( usually Ryobi stuff lasts well). Trying one of these now, for when it’s too much faff to put compressor on and use PCL airline Inflator. https://www.ebay.co.uk/itm/SKS-Airs...re-Gage-Multivavle-Kopf-for-all-/192951558885
Nope... It's Fubar...... "It is not possible to get a compensation/refund without sending a video of the fault code!!!!" Please send to this address [email protected] Delivery has failed to these recipients or groups: [email protected] A problem occurred while delivering this message to this email address. Try sending this message again. If the problem continues, please contact your helpdesk.
I've only ever used mm of Hg for vacuum or barometric (weather) measurements.... never tyre pressures! What industry uses that for pressures circa 1 to 4 bar?
Started a return.... I'd give these a miss unless you are retired* and are looking to waste a few hours. *Retired or TWAT'ing it... Working Tuesday Wednesday and Thursday..... like some old gits I know...
Having written bloody hundreds of manuals, of course I did. It was written in Mandarin, translated to Cantonese, then Shanghainese and then Ching'lish. I never seen so many words, with so little information..... I think our Forum member for the SNP may have originated the first draft. What happens when you press the little button next to the battery charge LED's? Huge pile of . Who bloody recommended this.....
