1200 Battery's
Discussion in 'Multistrada' started by damodici, Jun 17, 2014.
  1. OK.
    My Oct 2013 Pikes Peak Yuasa OEM battery has died.
    Could this be a sign from the gods?
    I felt after three weeks it was time to start her up and get out there.
    My last ride was Sunday 26th July on a Breakfast run with my little brother.
    Flat as a board.
    No red switch down, no added goodies to drain the battery.
    It normally gets ridden every other day or put on a Honda Optimate 5.
    This time I forgot.
    So now hunting for a greater capacity Lithium version....I've searched on here and will continue to see if I can benefit from the Hive mind.
  2. Motobatt all day long, brilliant batteries. I have had them on many bikes. When the battery goes on the Multi the yellow one will be straight on order! Not lithium I know, but streets ahead of regular batteries. Jon.
  3. Ordered, just under £50....saves me buying a new voltage tender (since I've got 5 the same)....and if I need to save a few pounds on the weight I know where to start first .....and it ain't the bike.
  4. Start at the Green Man.
