Best Place To By Clutch Fibers From?
Discussion in 'Technical Help' started by chizel, Jul 27, 2018.
  1. Lay the bike on side. No need to drain. 45’ should be enough.
  2. Its due an oil change anyway.
    But there is still a bit more involved in the cases and stuff isn't there? And with the dry one you can see what's going on!
  3. Don’t know never had one but don’t think it’s much different.
  4. From what I remember, the clutch itself is no different, although the slave arrangement is.
    Main difference is removing the whole side casing but it’s no big deal.
  5. As I suspected then.
    At the very least, this means you don’t need to drop the oil again if you do need to faff..
  6. Incidentally, why are you changing your plates??
    If it’s because they are slipping, I did that and it worked but not for long.
    Once the mayonnaise came back it was back to square one.
    The only cure was to regularly get it good and hot and leave the filler cap off to allow the steam to escape.
