1260 Bolt Length Nd Thread Size On 1260 Multi Bar Risers
Discussion in 'Multistrada' started by firecat0_0, May 7, 2026.
  1. Hi,
    Does anyone tell me the length, diameter nd thread size of the bolts used to retail the bar risers on a 1260 multi?
    Thanks in advance!
  2. If you are buying bar risers they usually come with new longer bolts?
  3. Thanks for your reply. I was going to machine the spacers myself they are simple enough and I can adjust the height to suite me hence the question.
    #3 firecat0_0, May 7, 2026
  4. 100mm long , they look like M10 but I would check the pitch , I didn’t have my glasses on
  5. Will do, after three attempts and two different eBay suppliers I finally have the material for the spacers!
  6. What height are you machining yours too ?
    Was 20mm or 30mm the factory item? Supposedly the stock cables are long enough to suit them.
