Brembo Brake Master Cylinder Seal Kit
Discussion in 'Technical Help' started by PeterT, Sep 6, 2019.
  1. Does anyone know if a seal/ piston kit is available for the Brembo brake master on my multi?
  2. I wondered what the elastic band in the kit was for, answered in the video of the replacement piston recall in post 65! Ten minutes with no movement
  3. ok, but I think that kit only fits the later style 16mm piston as used with the Brembo M50 calipers, mine is the 18mm I think, but need to check
  4. Hence the advice to call Craig at Moto Rapido to confirm, we can't all be aware of which version and MY of Multi you own as you don't specify.
