Can 38 Error
Discussion in 'Technical Help' started by Carl Hauxwell, Mar 27, 2022.
  1. On the ECU the CanBus wires are pin 20 and 29 on the body side to pin 19 and 26 on the dash.
  2. Bump. I've not got to the bottom of the problem. Relays have been changed. Still not doing anything.
    Bike is with a ducati mechanic and thinks its worth replacing the ECU. So has anyone got any recommendations?
    Question. I dont know anything about ECUs. My bike has termis, can I like for like replace with a used one? Is there anywhere that can reset a used one? Etc. Thank you.
  3. Immo meaning immobiliser?
    So I could purchase one of yours, take the old one off and off I go? No fueling issues etc?
    (If its the ecu and not the loom).
  4. Plug and play. Although a TPS reset is advisable but not essential.
    Just need to ID what map you are running. The labels on the ECU will provide the info.
  5. Bump.
    So, new ecu fitted, fuses checked and changed, new receivers, plugged and unplugged all over.
    Still got the *&**** error. Mechanic is tearing his hair out too.
    Not thinking loom as it's getting power to places.
    Any ideas?!
