Carbon Fibre Life Saver.
Discussion in 'Supersport (1974-2007)' started by Carr01, Dec 22, 2019.
  1. Bit of a sweeping statement, but if you say so...
  2. Wow,including Industrial brushware as well.;)
  3. MS Production manufactured Ducati carbon parts. Some carry just Their logo, some carry Ducati performance some both (my swingarm cover).
    Nice MS Production carbon tank here if you gave £2k plus and the right bike (gulp).
    https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.co.uk/ulk/itm/264407308307
    be interesting to see if you can renovate this without relacquering. Looks quite worn / thin in places. But nothing to lose having a go.
  4. In life?
  5. Pass,:confused:
  6. Take your time and don’t get aggressive rubbing down and you will be fine. It’s a nice bit of kit (or will be) that will add value as its genuine.
  7. It’s so thin you can see through it in places, re lacquering might be the way to go!
    Do you know of any suppliers. though not at the price of that tank!
  8. It did come over a bit like you were signing up behind Corbin mate. o_O
  9. Honestly have a go yourself first if you have time. You will be surprised st how well it will come up. My swing arm cover was similar. Very satisfying to do. If you screw up then no worries, a body shop who do sports cars (lotus etc) with lots of CF will fix for you.
  10. Dremel polishing pad and T Cut.
    The fading has disappeared and depth of the carbon fibre returned.
    Finished off with Mr Sheen!
    I wasn’t after an immaculate finish just wanted to get rid of the grey fading..
    Great job
    Thanks lads.
  11. That came up well with just a dremel. Nice one.
    Great depth, better lighting.
    I must have been smiling when I was using the Dremel, I can feel T Cut between my teeth!
  13. Good job! It should have worked off a couple of mince pies too.
  14. Put some wax on it now to give it some protection.
  15. You know that stuff that’s left in your mouth after the dentists has polished your teeth....
    T Cut!
  16. Nope,just a return of serve regarding the M&S owners:upyeah: .....did i hit the net slightly then.;)
  17. Saves going to the hygienist then.;)
  18. Congratulations Anthony on a wonderful job with very little ingredients you've managed to pull off a souffle.:upyeah:
    #38 XH558, Dec 28, 2019
  19. Or if you watch the other crap contest show, that makes you Strictly Come Polishing Champion 2019
  20. Play a let;)
