Carbs, Surely This Can’t Be Right?
Discussion in 'Technical Help' started by Mark9, Apr 14, 2018.
  1. Chris the small bore carb bowl bleeders don’t go the the vapour box, they just go “overboard” towards the bottom of the engine as with most other bikes, if I understand Al’s post correctly the single carb bleeder tube that does go the the vapour box is I believe just an air/vapour vent to prevent a pressure build up in the carbs.
  2. the confusion came from the red arrows on the diagram in post #20 - that's why I called them 'small bore' pipes.. as you were then..
  3. The carb bowl bleeders as you call them are also the float bowl overflow tubes - for example if the float gets stuck open; or if the fuel height is too high, you will see why they are 'overflow'.
    They will also drip (or run) if the tank pressure gets too much when the breather valve doesn't release when it should (a common occurrence) or when the tank has been brimmed and then left on a rear paddock stand although in that case it is more likely to drip from the tank breather hose.
    I extended the bottom of those tubes and clipped them to the rear edge of the fairing lower, otherwise they would drip just inside the fairing at the bottom and eventually make a mess of the paint - mine were turned outwards so that they didn't drip (or run) near the chain or rear tyre.
  4. As I said Al, in reality this rarely happens and the majority of fuel ends up dribbling into the crankcase via the inlet manifold. This happens on so many similar setups and maybe it’s more likely on ours because of the inclination of the carburettor bodies.
  5. Absolutely right Chris, which is why don't whack the throttle open when the 'choke' is on....
  7. I always hate it when I’m searching threads for answers to any particular issue that I’m trying to fix and all of a sudden the thread which I’m getting good info from just ends without the OP saying if the fix he/she was trying worked, so in case anyone looks through this one in the future here is a round up so far.
    1. The carb to inlet clamps I bought on eBay are good quality £5.40 for the set of four delivered, here’s the link
    https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.co.uk/ulk/itm/260724681596
    I bought the slightly larger clamps for the airbox to carb joints from the link that Arquebus posted, again they are good quality.
    2. The step remains on the slide guide, I’m convinced that the guide itself has deformed with age/heat, when I temporarily swapped the slide guide from the other carb it fitted without a step, I doubt it affects running but I will purchase a replacement soon.
    I finally had time today to put the fairings etc back on, hopefully it will not rain tomorrow so I will get out for a test ride, during the strip I found some of the jets were partially blocked, there was a lot of dirt around the diaphragms (from the breathers I assume), no major issues really, so now everything is cleaned and float heights checked it’s fingers crossed for a good run, the bike ran reasonably before but snapping the throttle open could result in a “stutter”, I’m hoping this was down to partially blocked jets or the carb inlet clamp being loose, if the “stutter “ Is still there it’s back to the drawing board !.
  8. Good news, running perfectly!, no hesitation in revs or stutter at all, just been out for a couple of hours giving it the beans and all is well, so either it was the partially blocked jets or it was drawing air at the intake rubber where the clamp was loose, I was forgetting just how good these bikes are! , totally addictive sound track, effortless acceleration, someone on this forum once described them as feeling “as though all friction has been removed from the motor” I know what they meant by that, wonderful machine!.
    Now as Columbo would say “there’s just one more thing”, I got fuel coming out of the fuel tank breather pipe, second time in recent weeks, I had just filled up but I don’t think I filled it any higher than I have over the last 3 years of ownership, I pulled the breather hose off the tank and blew down it, there was resistance when I blew (it allowed some air through but had to blow hard) then sucked and there was no resistance so I think the valve is working, maybe I am just overfilling?
  9. Umm, isn’t the idea that it lets air in to avoid a vacuum in the tank but doesn’t let it out?
    Valve wrong way round?
  10. I disconnected it at the tank end old rider so it’s the right way round.
  11. Aha
  12. I’ve started the bike quite a few times now since cleaning the carbs, it starts so readily now it’s almost worrying , previously the engine would need to turn over 3 or 4 times (one press on the button but turning over 3 or 4 times) before it caught, now it’s pretty much instantaneous!, hot or cold (with the choke on when cold of course), I mention it because you see a lot of threads blaming battery leads/earths for difficult starting, but it’s worth bearing in mind that if the carburation is off the bike will be more difficult to start.
  13. Indeed but poor carburation won’t make your engine slow to turn over and kill your sprag clutch
  14. Hi Oldrider, yes no effect there of course but I thought it worth mentioning as it’s such a marked improvement in starting, mines never really been a bad starter, I did put bigger leads on it but tbh it made no difference to cranking speed/starting so I guess there was nothing wrong with the original set up, clean connections etc.
