1200 Enduro Clutch Slave Cylinder
Discussion in 'Multistrada' started by Sotos christou, Nov 15, 2017.
  1. Advice needed. Assuming I want a lighter clutch on my enduro but want to retain its properties biting point etc what diameter slave cylinder should I be looking for. Stock is 25 mm and can find 26-28 and 30 mm??
  2. I fitted a CNC 28mm to my DVT, it is a bit lighter but so much smoother in operation than the OEM Slave cylinder so it was a worthwhile change. I was advised not to go for the 30mm as it may not fully operate the clutch in some circumstances due to more lever travel being required.
