748 Clutch Worn?
Discussion in '748 / 916 / 996 / 998' started by chunka57, Feb 12, 2018.
  1. Thought the issue was dragging.
    Do you have one or two mm of play on your clutch lever??
  2. Slipper clutches always seem to start with a friction plate.
    Is this bad news for bearings as well??
  3. I've no experience of slipper clutches but I doubt that that friction plate will be pressing directly against the basket. I've just watched a video of a slipper clutch being fitted to a Duc and the hub had an integral smooth plate at the bottom, which the first loose plate, which was a friction plate, would be up against.
  4. Top man! U were right!
    So I have 2mm plate out and adjusted the lever. 25 miles later still good. Thank you all.
    I presume now it starts wearing I will be refitting the 2mm plate.
  5. Only if it starts slipping, otherwise don’t worry about it.
