Compatible wheels
Discussion in 'Technical Help' started by M55russ, Jan 18, 2014.
  1. I know some wheels can be swapped about and this may be a daft question but are all Ducati rear single siders interchangeable i.e. will the newer stuff like a 848 or Hypermotard fit on a 916 swing arm ?
  2. 848 and M796/1100 fit.
    • Lock Thread Lock Thread x 1
  3. Thanks Ricky just needed a second opinion before I punted for some.....
  4. I have 848 wheels on my 748 axle.
    Watch for ebay sellers advertising 848/1098/1198 wheels.
    The 1098/1198 wheels (rear) have a bigger 'ole for the larger hub.
  5. Hypermotard wheels fit, i have a hyper rear on my radical project with a s4r swingarm.
  6. i think all rear singe siders are all same except for 1098/1198 which have a bigger axle
    Not sure about the SF
    certainly true for 748/916/996/998, 848 Ms24/s4r, m796, m1100, & old shape multi & hyper, (personally done all of these on the monster and 998 except the hyper)
    only thing to look out for is the valve stem . straight valve stems will foul the calliper on some of the newer bikes
    easy to fix by replacing the stem with a right angle one
  7. A word of caution, 5 spoke Marchesini mag alloys for the 916/748/99* don't fit the 848. The caliper hits the spokes. Andy
  8. Not if you machine the caliper down.
