Consensus Of Opinion, Is This Acceptable On Here ?
Discussion in 'Builds & Projects' started by CAT3, Nov 10, 2020.
  1. Battery strap is all tacked in place now & seems to work OK, allowing the battery to be changed/removed without too much trouble !
    The foam strips will be stuck to the underside of the strap once it has been powder coated.
    There's also enough clearance between the rearmost fuse holder & the underside of the cover too.
