All af a sudden running rough, getting hot and popping exhaust.... Diagnosed: No ruptured fuel line in the tank, No vacuum leaks, no coil leads plugs arcing, no head gasket gone, No coolant loss, running fine when cooled down. The culprit: Crank sensor giving up after 25 years and 28k km.. Changed ignition leads just to be sure... asking Google Gemini about Ducati electronics.... " It truly is a rite of passage! There’s nothing quite like 90s Magneti Marelli craftsmanship to keep you on your toes. The Italians designed an absolutely masterpiece of an engine, wrapped it in beautiful bodywork, and then seemingly used whatever wiring and sensors they could find at the bottom of the bin on a Friday afternoon before lunch. When it works, it’s pure art; when it heat-soaks at a traffic light, it turns into a rolling espresso machine of chaotic signals. Look at the bright side: once you swap out that 25-year-old sensor and those tired leads for fresh, modern components, you’ve effectively purged the most notorious Italian gremlins from the system. It’ll run crisp, smooth, and predictable again." ------ same shit happened on my Alfa Romeo 156 crank sensor.... gave up twice... "Ah, the classic Alfa Romeo 156 experience! That is the ultimate proof that Magneti Marelli and Bosch components from that era share the exact same genetic DNA code: "Works beautifully until it touches 90°C, then takes a mandatory 20-minute siesta." On those 156s (especially the Twin Sparks and JTDs), the crank sensor failure was practically a scheduled maintenance item. You’d be driving along perfectly, pull up to a junction or get stuck in traffic, the cooling fans would kick on, and boom—dead engine. You'd sit on the side of the road for 15 minutes, cursing in Italian, and the moment it cooled down to 70°C, it would fire right back up like nothing happened. At least on your 996, the sensor is giving you a dramatic, erratic light-and-sound show with the exhaust popping before it gives up, rather than just pulling the plug entirely like the Alfa did. The silver lining here is that you’ve already been thoroughly trained by the best of Italian automotive engineering. You already know the exact pattern of the crime! Replacing that 25-year-old sensor and those tired leads on the 996 is going to feel incredibly satisfying once that crisp, rock-solid idle returns. Spanners out, a good cup of coffee (or an espresso, for thematic accuracy), and you’ll have those gremlins evicted in no time! "
