Dds Map Key
Discussion in 'Technical Help' started by s4rmark, Jun 18, 2026 at 7:35 PM.
  1. Can anybody tell me what the DDS Map key actually does ?
  2. A USB stick with a new fuelling map on it which plugs into the dealer’s Ducati Diagnostic System aka DDS aka their laptop/computer with the diagnostic software on and which then permits the dealer to load the map into the bike’s ECU. used on bikes from around 2014-18 which had Termi or Akra systems fitted by the dealer.
  3. Thanks for the reply. So , is it really worth getting for just a slip on? The fuelling on my bike seems to be pretty good with just the sc pipe.
  4. Two things to bear in mind…
    They are bike, even exhaust kit specific, as they were only supplied with the exhaust kits. You couldn’t buy them on their own.
    Secondly, once they have been used, they are locked to the bike. Unless the process is reversed and the stock map transferred back on to the bike, the key won’t work on a second bike unless this is done.
