Enduro 1260 Pillion Pad
Discussion in 'Wanted' started by Nasher, May 18, 2025.
  1. A long shot I know.
    I'm looking for a replacement Multistrada 1260 Enduro Pillion Pad.
    From what I can see the Enduro pad is different to the other 1260 MS pads, and the 1260 is different to the 1200, so it's a rare thing I'm looking for.
    I don't mind the colour, my current one has the Sand coloured patch in the middle so I can even put up with that if required.
    Ta.
  2.
  3. Not sure how the pad is manufactured, but could you have it recovered in your own material to personalize the bike? Just a thought.
  4. I should have explained that there is nothing wrong with the one I have.
    I want to try a mod to give more room in the storage compartment underneath but don't want to ruin the one I have.
  5. Perhaps you could get an upholsterer to simply put at black cover over the top of the current, one which you could later remove if you wanted to?
  6. Shouting out to @Hugo Magnus , he has a barn full of bits.
  7. Nothing to do with the cover Jez, it's the underside I'll be modifying, hopefully without touching the top side.
    Many thanks.
  8. The bits I have are for a 1260s
  9. Ah, thanks anyway HM.
  10. Sorry, I thought @Nasher ’s was the 1260
  11. Yep, it is a 1260, but being the Enduro version I believe both the riders seat and Pillion pad are a different shape to the other 1260 Multis, with a different plastic moulding underneath.
    Unless somebody can say for sure that that statement is incorrect.
  12. They might share the same seat pan but with different foam and/or covering? You need to find someone local, or a friendly dealer, with the regular 2015> 1200 or a 1260 who'll let you try.
