With after market cans do the link pipes usually have gaskets were they join the silencer? Or is it just a metal pipe into the silencer? If it has gaskets where can you get them Cheers
I think it depends, my termis use the gaskets, my race fit doesn't use any so I use some paste. You can get the gaskets at your local dealer, I use alfs in Worthing. Can't remember a part number but they can find em pretty easily on the parts database diagrams.
Might be worth checking the springs and replacing the blue rubber damper too, behind your right rear set.
Is the blue damper the rubber thing near the rear or the fairing behind the peg? I have ordred new springs to go on, thanks for that the others did look a bit rough, found a parts list online and ordered the gaskets from the nearest dealer so a good
