Fischer Future Heat
Discussion in 'Lounge' started by PerryL, Sep 17, 2020.
  1. Very reasonable offer but I think that I may pass!
  2. spoil sport
  3. To be fair tried it ! But it’s only short term fix ( as my box hedge found out )
  4. And ya fancy trainers! You forgiven jo yet?
  5. Yea as she pointed out whilst the flames were licking round my legs and my socks were melting to my feet - she bought me the trainers :yum
  6. I'm moving next week but that might not be quite the house warming I'm looking for...
  7. Good story bro (EDIT: aimed at the installer, not Perry).
    There are hundreds and hundreds of verified complaints, enough to get Which Magazine and the ASA involved.
    These complaints revolve around
    • Pressure Selling (not applicable in your case).
    • False claims of Green Credentials
    • False claims of savings.
    • False claims of efficiency*.
    • Bad mouthing of other technologies.
    *Even at frost temperatures air sourced heat pumps are 250% efficient.
    No matter what the season you will get only 100% efficient from that Fischer electric element.
    All the kW/hr used will turn to heat (hot water) at 15p a unit.
    If you had stuck with gas it would have been 97% efficient at 3.5p per kW/hr.
    You would have been better off with a Combi.... instant heat (if you installed radiators) and hot water.
    You didn't need a hot water tank.
    Just so you know what you have was designed for Off grid storage of energy.
    Phase change material = PCM
    Collect electricity from renewables when available then store it in a high PCM dense* core to be turned into hot water as and when required.
    You've effectively got a very expensive hot water tank "capability".
    A bit like your storage heaters, but with a much higher specific heat.
    *So the only thing that is thick in this debate is the core at the centre of that storage brick.
    Uncap the gas, switch back and get yerself a proper heating system.
    23 million UK homes can't be wrong?;)
    https://www.theccc.org.uk/wp-conten...-Committee-on-Climate-Change-October-2016.pdf
    #47 AirCon, Sep 19, 2020
  8. aBSOLUTELY NOT! I DON'T WANT GAS! You will be suggesting chopping down trees next!
    The thought that I will never again use gas and will never again have a gas fitter in my house sucking in air through his teeth and telling me that "it is not a simple job" fills me with unending joy!
    This device will not last forever and if that occurs then I will replace it with either the same (if Fischer give me a good discount) or an instant hot water heater (where Fisher put theirs has given me an idea as to how I could wire it up from the junction box).
    S
    I have not got a hot water tank because it stores no water. It was very expensive but I knew that from the start and decided to give it a go.
  9. I'll leave this for now as I think you are looking at my posts like this.....
    :kissing:
    #49 AirCon, Sep 19, 2020
    • Funny Funny x 6
  10. I would buy nothing from a cnut like this....
  11. If you’re happy then that’s all that matters
  12. Ok, where do you live?
  13. Thats because they have shares in BP.
  14. Let's stick to basic physics. 100 percent efficiency is impossible. 250 percent is ludicrous. That would mean something creates energy. Energy isn't made or lost it just is. When we convert it through physics or chemistry we have loss. I don't know this fisher system but reversing a chemical reaction via electricity so it can happen again to heat some water does seem a extra step in the process. The amount of energy needed to heat a defined amount of water to a certain temperature is always the same provided the conditions are the same. On the face I would agree that a 2 step process doesn't sound efficient compared to any equivalent single process system. Emphasis on equivalent.
  15. 437FD50C-517E-48DF-B389-09EB73F87C35.png Is this a good place to leave this?
  16. Thanks again but we are miles out in the sticks so no gas, stuck with electric or oil :thinkingface:
  17. What about Calor Gas and a big holding tank? That’s what we have.
  18. In a land far far away... its called far away land...
  19. Or southall by the natives...
  20. That's gotta be locked down by now.
