916 Head Stand Pin Size
Discussion in '748 / 916 / 996 / 998' started by Regenwulf, Jul 11, 2019.
  1. Apologies if this has been dealt with before - I did search but struggled...
    Can anyone confirm the correct pin size for an under yoke front stand for the 748/916/996/998 etc series? I presume they're all the same...?
    Cheers,
    jm
  2. They don’t have them as std. lots of people have done the mod but requires the front end taking off.
    If a previous owner has drilled a hole there already, just measure it and use the right pin for the job. Most under yoke stands come with a selection of pin sizes. IIRC, you won’t be able to go much wider then about 20mm as it’ll get too close to the steering stem. I put my stem in a 3 jaw Chuck on the lathe and put a 16mm hole in. (Keeps the hole central).
  3. Aha, thanks!
