Im off to see him this morning Funkatronic. Apparently the same issue occurs with all keys. Is there any way to test the antennae once we have the cover off?
its just a coil of wire i think. you can use a multimeter on its ohms setting across the antennae terminals. if its dead it'll be open circuit and give no reading. if its working you should see a pretty low (probably 0 ohms) reading
It is common for the antena to fail on Ducati's I have had three on my 1098 They are around £25 from Ducati Just get a new antena
Quick update. We dropped up and saw him and the ignition lock cover is bolted down as part of the fairing. He is going to remove all that when he has time and I'll go have another look. Hopefully its just a bad antennae
