Home Engineering
Discussion in 'Other Bikes' started by bradders, May 9, 2020.
  1. Using what’s to hand, bit of thought and no mechanical skills.
    problem: stand is too far under engine to reach on anything other than flat or ok camber. Which is most
    solution: weld something higher up the stand
    solution when you don’t have stuff and cant weld: adapt, overcome, succeed....
  2. Sweet, simples!!:upyeah:
  3. Short arse!! :joy:
  4. How did the other umpalumpas overcome it?
  5. I haven't encountered a bike yet that I can't get both feet on the floor, with knees slightly bent. :bucktooth:
    Although I can sometimes get a bit of leg ache on sports bikes after a day out, I'm glad I don't have that chew on or nervous moments at the lights. o_O
  6. I can get both feet flat on my r1 but struggle on the panigale.
  7. Get some heels shorties
  8. Short Arse !! :joy:
  9. No need. I manage with no problem with my regular riding boots. :thinkingface:
  10. You won’t get it between the peg and gear change.
    :p
  11. I never change gear. I just keep it pinned in 1st, it saves unnecessary wear on the gearbox. :)
  12. He doesn’t ride his bikes they are in perfect condition in the perfect garage dont you know :D
  13. Even his dust is at right angles, all perfectly aligned :D
  14. They always rode in pairs.
    HTH.
  15. I went out on the Tuono last week and the Triumph on Thursday. :innocent:
    I'm hoping Boris allows me to go further afield from tomorrow, then I'll be pinning the Tuono around the lakes in 1st gear like a right hoonigan. :cool:
  16. Dust ! Where? o_O
  17. Why not pull away in 2nd, give 1st a break?
  18. Because it'll chug a bit and cause damage. My method is best. :)
    #18 Robarano, May 9, 2020
  19. Launch control :p
  20. Beggars belief, but where BMW owners are concerned ............... believable !!
    We can just add this to all the other sad things they do,
    Don't wave to non BMW riders.
    Wear rediculous "POLITE" day-glow vests.
    Park their bikes the same way round when out together.
    Only wear BMW branded clothes, (although HD riders fall into this bracket too !!)
    And so on ......... :joy:
