V4 How Do You Work On Your Front Wheel
Discussion in 'Multistrada' started by ymfb, Apr 6, 2026 at 7:51 PM.
  1. Sometimes I have to ask Mrs YMFB to lean on the back of whichever motorcycle I’m working on so I can rotate the front wheel. I have a roller somewhere, but to deploy that also needs Mrs YMFB. Should I be getting a front paddock stand or something else?
  2. Yes
  3. Which one or type for a V4S Multistrada
  4. Anything with a L shape adapter fitting will do. Which is most of the cheapo ones
  5. I've had mine for years, it's done, many GSXR's, R1, KTMSDR1290, 1299 etc, I've had to modify it so I can get the axle out and raised it so tyre warmers would rotate, it's similar to the one in the link,. Not how you'll get on with a 19" front wheel so it clears the ground, I would do a bit of research to ensure enough height. It's pretty stable, never had any issues.
    warrior-front-paddock-stand-ubrpdsfrt
  6. I bought one recently with the pins, works a treat and feels safer than those rotating bracket type
  7. Height is your main concern, to make sure it can in fact lift the front wheel off the ground, many don’t.
    Better still, treat yourself to an Abba Skylift.
