1200 Indicator Idiot Light Erratic Flash
Discussion in 'Multistrada' started by SImple SImon, Sep 8, 2024.
  1. Hello,
    Just back from a long weekend tour of Normandy and noticed a slight issue on the dash.
    Periodically, the right indicator idiot light either wouldn't illuminate or would have a bit of meltdown & go mental. After a few seconds it seemed to settle down and flash as normal.
    Annoyingly, I couldn't put it down to being warm, cold, wet or dry. Also when it happened, I couldn't check to see if it was impacting the actual light. As it always seemed to occur at a time when I was unable to stick my hand in front to check.
    Is this a known issue (can't find anything)? Or worse, the harbinger of something more serious!?
    Thanks in advance.
  2. What model Multi do you have and are the indicators stock or aftermarket ?
  3. It is a 2015 1200 S GT, running the stock indicators.
    Thank you for the tip on Carmo. I've used ACTronix to get an ECU repaired previously and they're based in the UK.
