1299 Inertial Sensor, Des, Scu
Discussion in 'Panigale' started by Brom66, Jul 7, 2017.
  1. Had these come up tonight on the dash, I gather they are to do with the suspension etc,
    Tried the normal ignition on off 3x.. no change
    Left ignition off for 10 minutes, switched on and they have disappeared !!!!
    Can anyone give some light on why this has happened ?
    All I've done is change tyres from SuperCorsa to Bridge S21.
    Off for a 3000 mile Europe blast on Sunday tbh don't need this shit lol !!
  2. I understand from a similar post elswhere that somewhere in the set up menu there is a tyre calibration function for when you change tyres. Might be wrong but worth a punt. Andy
  3. Just found this in the manual, a phone call in the morning me thinks !!!
    Tyre Set-Up
    If owners install different tyres than original
    equipment ones and yet belonging to the classes
    specified by Ducati, this function allows them to
    recalibrate the system. It also allows system correct
    recalibration of all controls (such as DTC DWC EBC)
    in case the owner changed front and rear sprocket
    ratio, so that all motorcycle control systems can
    consider these changes / variants and adapt their
    processing parameters accordingly.
    From the Setting Menu, it is possible to start the
    teach-in procedure of the new rolling circumference
    and new final drive ratio or restore the default
    settings as established by Ducati for OEM outfit.
    To do this, you must enter the Setting MENU.
    Select TIRE SET-UP option, by pressing button (1) or
    (2). Once function is highlighted, press CONFIRM
    MENU button (4).
    You open the TIRE SET-UP Menu.
    Press buttons (1) and (2) to select START or
    DEFAULT: the latter can be selected only if the
    motorcycle is currently not set to the factory default
    configuration.
    To exit the menu and go back to previous page, select
    EXIT and press button (4).
    Teach-in procedure
    When entering the function, the vehicle speed and
    gear engaged are indicated on the right, while the
    instructions on the required speed range and gear to
    be engaged to correctly carry out the procedure are
    displayed at the centre.
    Speed range: 48 รท 52 km/h (and corresponding value
    in mph if set unit of measurement is mph)
    Gear: 2
    The first page indicates READY in red at the top of
    the display to warn the rider that the system is ready
    for the calibration procedure.
    When the rider complies with the required conditions
    of vehicle speed and gear displayed, system
    calibration will start and an orange IN PROGRESS
    message will be displayed at the top.
    If procedure is successfully completed,
    COMPLETED message in green will come on at the
    top of the display, and after a few seconds it will be
    automatically replaced with the main screen.
    If it is not possible to start the procedure when the
    START is confirmed, after a few seconds the
    instrument panel will automatically highlight the
    option EXIT.
    If an error or malfunction occurs during the calibration
    procedure, FAILED message in red will come on at
    the top of the display, and after a few seconds it will
    be automatically replaced with the main screen.
    The rider can abort the procedure both during the
    READY stage and during the IN PROGRESS stage, by
    pressing button (1) for 3 seconds. ABORTED
    message in red will come on at the top of the display,
    and after a few seconds it will be automatically
    The values shown in the pictures as required speed
    range and gear are just an example and shall not be
    considered as binding or corresponding to the ones
    actually set for the vehicle.
    Restoring default settings
    Open the TIRE SET-UP Menu.
    Then use buttons (1) and (2) to select DEFAULT and
    keep button (4) pressed for 3 seconds.
    For a few seconds the message PLEASE WAIT... will
    be on the display.
    If the procedure for restoring the default settings is
    successful, DEFAULT OK will be displayed for 2
    seconds and after a few seconds it will be
    While, if the procedure for restoring the default
    settings is not successful, ABORTED will be
    displayed for 2 seconds and then the instrument
    panel will automatically display the main screen of the
    TIRE SET-UP menu with highlighted EXIT item.
  4. Sod that I would have just fitted pirellis. Couldn't be arsed for all that!
  5. Yes agreed, but I don't think they will last the 3000+ miles I'll be doing in the next 10 days,
    S21's are still 200/55/17 so don't know if it was just a glitch or ??
  6. It's really not that big a deal. I changed the settings when I fitted Metzeler M7RRs. Took all of two mins to calibrate the bike, which also takes into account the rear sprocket change to 41 teeth.
  7. I've changed tyres and gone to 14t front sproket and did'nt have any issues. I've not done any of the recalibration, my bike seems fine as is.
  8. Done 900 miles since then, and it has not come on since.!
    But now I'm in Andorra brokedown with engine management and no quickshift which looking at the manual they are related so hoping will be on my way sooner rather than later..
    And Ducati Roadside Assist supposed tube here at 8 o'clock it's now 9.30...still waiting
