Isopropyl Alcohol, Ratio?
Discussion in 'Technical Help' started by Mark9, Oct 29, 2018.
  1. 4.76 to 1dp isn’t 4.9.
  2. It was the assertion that 5% of 105 is 4.76 that was throwing me.
    I was being too dim to realise what he was trying to say is that 5ml is 4.76% of 105 ml.
  3. Stop being a prat Jon.........4.76 when rounded up to one decimal place is 4.8 so who gives an F about 0.1 unless it is the size of your d... (head) in your mind?
    It wasn't the original point I made so go and play with yourse** or your calculator - I don't effing care.
    To be honest, I don't give an FF whether I'm on this forum or not, so if I get banned for calling you a c*** then so what. Eff off and stop trying to be clever.
  4. Pathetic.
  5. Then there is "Proof" to think about, it too is expressed as a percentage, 50% alcohol with 50% water is 100% Proof alcohol (the drinking kind).
  6. This threads just a bit of silly fun. No need to get abusive. Anyway. 4.76 to 1dp is 4.8.
  7. Anyway, does anybody know how much IPA I should add to a tankful to remove water from the fuel? :)
  8. How much Ipa can a 75kg man drink and still operate power tools safely? 5% of body weight? 3.75kg?
  9. Just in case a direct answer is still needed:
    Adding IPA to your tank (in any amount) will not remove water from the fuel.
    In reality it will do the opposite and attract more water.
    It can solubilise some water droplets you might see in the bottom of the tank and mean you can’t see it any more, but the water is still there.
  10. This a funny thread
  11. I wouldnt waste a pint of IPA in my tank.
  12. India pale ale or iso propyl alcohol?
    I know, I know... both :p
  13. Both alcoholic - ish...
  14. If i drink loadsa pints of IPA, i get a hangover coz it dehydrates me.
  15. I would only use one of them to clean the stylus of a record player. (Blast from my past but now apparently back in!)
  16. the water is still there... unless it’s on the wall round the back of your local?:beer:
  17. i can usually make it to the loo. In fact, i always make it to the loo. Whether to chuck up or urinate is besides the point. But i prefer to utilise the correct recepticle. Im a respectable fellow dont you know.
  18. Never doubted it for a moment ;)
  19. Würth fuelcure
  20. Holy thread resurrection
