1200 Long Term Multistrada Running Costs
Discussion in 'Multistrada' started by Mamamali, May 23, 2018.
  1. Guys, already posted this on the most unreliable thread but thought It was worth one on it's own, largely cos it took me ages to do ha ha
    As my multi gets to nearly 5 years old and is about to click past 30,000 miles I thought I'd add my 2 pence worth. It's by far the best bike I've ever owned after a lifetime of reliable Hondas and some Aprilias. In the first three year I had a fuel sender go along with the heated grips and a throttle cable recall all at 15,000 and all done under warranty, on the extended ever red warranty the following year I had front brake reservoir and starter solenoid go and that was pretty much it apart from a few cosmetic bits and bobs once again changed under warranty. The 30,000 service price from the dealer was over £1,000 so decided to go independent. It was during that service that unusual wear on the vertical inlet cam was noticed, looks to be a problem with the case hardening going, no chance of goodwill with it being at an independent and with the cam, follower and rockers costing over £900 new I found some second hand bits for £200 and got them fitted. I did the oil, oil filter and air filter myself and the rest was done by the indie for less than £400. Since new it has not needed a valve adjusting and after nearly 30,000 mile I've finally had to replace the rear sprocket and front brake pads. Finally the mud guard had worn through the braiding on the brake hose that links the two front calipers together so got one made up locally. Numerous trips to Scotland and Europe, thrashed down back roads and the A roads of north Yorkshire and I am over the moon. Here is to another 30,000 mile !
    Run down of costs as follows;
    date mileage item cost
    24/07/13 0 Multistrada 1200 with heated grips £12,300.00
    14/08/14 7150 Oil and filter service £196.14
    14/08/14 7150 year 3 warranty £280.80
    15/08/15 14,930 15,000 mile service £676.05
    15/08/15 14,930 front sprocket £21.00
    27/10/15 15,920 Front brake reservoir replaced under warranty £0.00
    27/10/15 15,920 EK530-108MVXZ gold chain £79, fitting £35.40 £114.40
    20/04/16 16,686 Starter relay/solonoid replaced under warranty £0.00
    15/08/16 21,200 Battery £60.00
    11/10/16 22,450 Service £238.12
    14/10/17 28,264 Motul 300v 15W50 Oil £49.49
    14/10/17 28,264 Oil filter 44440035A with sump washer £11.50
    17/10/17 28,404 air filter ebay bargain £22.00
    07/05/18 28,848 Belts/valve check/plugs/coolant/fuel filter £395.00
    03/01/18 28,848 chain and sprockets - Afam - Ebay £195.00
    07/05/18 28,848 inlet cam and rocker repair - used parts £211.00
    07/05/18 28,848 inlet cam and rocker repair - labour £280.00
    07/05/18 28,848 fit chain and sprocket £40.00
    10/05/18 28,965 Front brake cable £36.00
    12/05/18 28,965 brake pads Brembo OEM £72.00
    total costs £15,178.63
    running costs without tyres and fuel, insurance, mot etc £2,878.63
    • Useful Useful x 3
  3. Great to hear a good news story about these bikes, expecially as i think i might be about to buy a second hand one to replace my greatly missed ST4S .
