848 Looking For 26mm Bore Clutch Slave Replacement
Discussion in '848 / 1098 / 1198' started by tboooe, Oct 18, 2020.
  1. Hi, I want to replace my OEM clutch slave with something aftermarket that looks a bit better. I am not interested in getting one with a larger bore (28, 30 mm) as I really like the short pull I have with the OEM unit. Does anyone know of a good aftermarket clutch slave that is available in 26mm bore? Doing a quick internet search I see that CNC Racing used to offer a 26mm clutch slave but I no longer see them on their website. It seems they are still available from some vendors like this one but I am not sure this model will fit my 848 because only the 1199, 1299, 859, 959 is listed.
    Thank you!
  2. The Oberon ones look good, but I think they are 29mm bore?
  3. Thank you for the reply. Yes Oberon is 29mm. I've read stories about people who've upgraded their clutch slave to one with a bigger bore having a much longer lever pull to disengage the clutch or not being to fully disengage because the push rod doesn't travel far enough.
    Anyway, I found some ebay sellers in Italy that seem to have old stock of the CNC Racing 26mm clutch slave. After a bit of research, it seems most Ducatis apart from the Panigales use the same clutch slave.
    https://www.ebay.com/itm/CLUTCH-SLA...rentrq:3bec06d31750a9bd34ec5486fffa8af4|iid:1
  4. Unfortunately the eBay ad says they don't ship to the UK...
  5. Sometimes it's good to be an American then!
  6. Ah, missed that!
