999 Mot With Non Road System
Discussion in '749 / 999' started by RC1, Apr 23, 2025.
  1. i need to get mine MOT'd but it has a rather lovely leo vince 57mm corsa full system
    is this likely to fail mot or could a friendly mot tester overlook it if i rock up with the standard system in the boot of my car?
  2. I thought a noisy exhaust was an advisory? If it has a baffle I would hope that it would definitely pass?
    An MOT guy could fail it, but do they ever -for just a little extra noise?
    @cookster
    MOT inspection manual: motorcycles
    Driver and Vehicle Standards Agency
    Published 20 May 2018
    Updated: 6 February 2023
    8. Exhaust noise
    Exhaust noise rules and inspection for motorcycle MOT tests.
    8.1. Noise
    8.1.1. Exhaust noise
    If possible, you should assess the exhaust noise by revving the engine to approximately half the maximum engine speed. The engine should be warm before you carry out this check.
    It is not possible to rev the engine on twist and go type motorcycles.
    The exhaust system and silencer should be in such condition, or of such a type, that the noise emitted from the motorcycle is not clearly unreasonably above the level expected from a similar motorcycle with a standard silencer in average condition.
    Defect Category
    (a) Exhaust noise levels in excess of those permitted Major
    (b) Any part of the exhaust system:
    (i) insecure
    (ii) likely to become detached Major Dangerous
    #2 Jez900ie, Apr 23, 2025
  3. My not for road use exhaust on my MV passed at my local MOT station with an advisory.
    I guess it’s down to the individual tester as to whether he spots the ‘not for highway use’ label.
    I use the same place for all my bikes and haven’t failed a test yet.
  4. I get MOT noise advisory ever year with a full-race system.
  5. Yeah as mentioned it should fail if it has not for highway use on it or if its ridiculously loud, like them stupid Austin racing cans !! If you fit a baffle it will definitely help your cause.
  6. My 749R always passes with a full 57mm system. I do however fit baffles for the test.
  7. I invariably take biscuits and make the Tea or Coffee, this often helps.:)
  8. there is no decibel meter used during an MOT so it's opinion init. like around 90% of an MOT. and what you cant see you cant fail.
    the only time i ever failed a vehicle for "Excessive" exhaust noise funnily enough was on a policeman's Subaru Impreza. he was cool about it.
  9. brilliant thanks all... i will buzz my mot man ahead of my planned arrival
  10. spoke to local friendly mot man - bike all booked for next weds and hes become hard of hearing recently and should any markings be obscured then he wont know whats under the duct tape that has strangely attached itself to the silencer
  11. Discretely get rid of the "not for road use" wording if there is any. My 996 didn't even get an advisory for no baffles, but it's not that loud, 102db
  12. Post #10 covers this well enough.
  13. I wouldn't use duct tape as it will melt.
    Mine has a thin strip of HiSpeed tape over the wording, firmly pressed on with a plastic scraper to blend in to the silencer.
    One can buy Ally tape which would be equally good.
  14. On my Monster's MoT - the last one before it was killed, where it it had Termi silencers (or lookalikes) and passed - that was what the tester said to me. They don't have dB meters as part of their equipment for MoTs:grinning:
  15. A dremel is very handy for removing and then polishing any unwanted engravings...;)
  16. any my angle grinder
  17. The termis on 916 models have 'race use only' stamped on the top of the band at the front of the can which can't be seen when the cans are fitted to the bike plus, if you polish the cans then it may be erased anyway.
    I was talking to an MOT tester recently, he said that he would only fail an exhaust that was either faulty, i.e. holes, leaks or hanging off or if it had 'race use only' or similar that was visible.
  18. Nigel will pass this full system with zero questions mate.
  19. spoke to him this morning all sorted
    means we can go out for a blat soon
  20. Took my sons 125 in for the MOT and got this “pass”.
