Multi 1200s Touring, Air Filter
Discussion in 'Technical Help' started by Broduc64, Feb 7, 2020.
  1. How to change Multi air filter pls.
    Searched, but can't find a link.
  2. Anyone..... please...
    I've had a look but seems to be having to remove one part after another ?!?!? Can't believe a serviceable part would be so awkward to get at...
  3. #3 noobie, Feb 7, 2020
  4. Hi @Broduc64 I'm not sure what mode / year you have but it's fairly similar regardless. I've put a copy of the 2015 Workshop manual on a Google Drive (Copy of MTS1200S 2015.Workshop Manual.E4.pdf), the air filter serving is on page 111. The manual is not an official Ducati copy as it no branding and is a bit rough around the edges.
    If you've got a 2010-2014 model, then let know as I've got a CD of the workshop manual somewhere,#
    Hope this helps.
  5. Mine's a 2016 S, so should imagine is pretty much the same.
    Thanks.
  6. Whooa, no wonder it costs so much to get these things serviced. I am exhausted from just watching that guy get to the air filter. That really is a crazy amount of work to change a service item ....
  7. If you have a pre DVT it's a peice of cake. If DVT then tank off.x
  8. Well, if my tank needs to come off, it'll be a K&N filter going in the airbox so it never needs doing again.
  9. That's why I was taking it off. Reduced maintenance.
  10. Done it... Not 1 nut or washer left over :upyeah::cool:.
    Made worse by having to remove crash bars too.
    With hindsight I should've bought new spark plugs and changed them at the same time....Oh well, at least I know how to do it now.
