V4 Multistrada V4 Front Brakerake
Discussion in 'Multistrada' started by Bertie, Feb 23, 2026.
  1. Hi guys my first post !!
    Multistrada v4 2021 60000 miles
    Had the front brake master cylinder replaced at about 5000 miles due to air leaking in( warranty)
    It's gone again , can this be repaired.
    If not, any recommendations on an aftermarket unit which has worked on this bike?
  2. If work done at dealer and a known issue I’d take it back to the dealer. Also make they put a note on the system that a warranty replacement has failed again(same issue).
    Was the replacement an updated part?
  3. 55k miles later?? or is that a typo? not sure warranty will be any use 55k miles and years later. will leave tech responses to someone better qualified than me :)
  4. Warranty was 100000 my keys and 4 years.
    Current mile on the bike is 60000
  5. If it's the same air intake failure, straight back to the stealership. Else, use this chance to upgrade the MC?
  6. Found out that this part cannot be repaired from a brembo service engineer.
    However the brembo RCS version will fit with a slight modification as well as being serviceable
