*new Ducabike Parts*
Discussion in 'Conquest Racing Ltd' started by Conquest Racing Ltd, Feb 15, 2023.
  1. On this thread, we will be actively letting all members know of new products we receive in stock for the great CNC parts manufacturer that is DUCABIKE.
    To those who may not know who DUCABIKE are, well here's some info........
    Based in Bolognia (Italy & just down the road from the Ducati factory) Ducabike creates stunning CNC parts for Ducati the parts they make range from rearsets to complete clutch kits as well as their famous clear clutch covers for modern wet clutch models. There's not much they don't make for Ducati's so I'm sure there will be something for your model.
    DON'T FORGET TO ASK FOR YOUR FORUM DISCOUNT CODES, EXCLUSIVE ONLY TO FORUM MEMBERS!
    https://conquestracingltd.com/shop/product-category/ducati-performance-parts/
  2. beautiful parts
  3. Ducabike Ducati Monster 937 Black Ohlins Steering Damper Kit
    Protect yourself from unwanted tank slappers with this Ducabike Ducati Monster 937 Black Ohlins steering damper kit.
    Ever had that heart-stopping moment when the bars oscillate nervously or even flap uncontrollably out of your hands? If you have, you’ll know it’s no fun… if you haven’t… you should act now before it happens…
    What you have experienced - or probably will experience sooner or later - is the problem known as a tank slapper, which, if it becomes violent enough (as it easily can), often leads to an accident.
    Tank slappers happen when a bike’s front wheel leaves the road surface momentarily (or for longer if the bike is wheeling) and move from the straight-ahead position whilst airborne (this almost always happens if the rider touches the front brake which stops it from rotating and thus loses its gyroscopic resistance to turning).
    Fits: Ducati Monster 937 (all variations)
    #3 Callum-Conquest Racing, Feb 15, 2023
  4. Ducabike Ducati Streetfighter V2 Rear Sprocket Flange Carrier
    Ducabike’s Ducati Streetfighter V2 rear sprocket flange carrier is made from 7075 billet aluminium and hard anodised in several lustful colours perfect addition to your Ducati Streetfighter V2.
    Ducabike specialises in performance CNC racing parts for all Ducati models.
    All products are made in Bologna Italy and designed to complement the aesthetics and performance of your Ducati Streetfighter V2.
    Fits models:
    Ducati Streetfighter V2 (All variations)
    https://conquestracingltd.com/product/ducabike-ducati-streetfighter-v2-rear-sprocket-flange-carrier/
    #4 Callum-Conquest Racing, Feb 16, 2023
  5. Ducabike Ducati Front Fender Screw Kit
    Made solely by Ducabike, these beautifully made front fender screws are designed to provide your Ducati with a more aesthetic appearance.
    Machined from billet CNC 7075 grade aluminium and given a lustful hard anodised finish.
    Features:
    • Machined from 7075 billet alloy​
    • Aesthetic design​
    • Available in 3 colours​
    • Interchangeable with the originals​
    • Kit x4 pieces​
    https://conquestracingltd.com/product/ducabike-ducati-front-fender-screw-kit/
  6. Ducabike Ducati Streetfighter V2 Adjustable Brake Clutch Levers GP1
    Made solely by Ducabike, these Ducabike Ducati Streetfighter V2 adjustable folding brake clutch levers GP1 are just that they fold in case of a drop or spill, they have x5 adjustments to the reach and air blades to prevent wind resistance, they provide better feedback from the front brakes and a lighter clutch pull.
    Ducabike/Performance technology found that with nearly all levers on the market manufacturers design them in a square profile which after a long ride makes your fingers ache so they have designed theirs with a round tapered edge (as shown in the diagram below), this not only provides more comfort but also makes the lever feel like you’re not using as much pressure, therefore a far more comfortable lever.
    Machined from billet CNC 7075 grade aluminium and given a lustful hard anodised finished. Ducabike is based in Bologna the same city as the Ducati factory.
    Fits Ducati models:
    https://conquestracingltd.com/produ...ighter-v2-adjustable-brake-clutch-levers-gp1/
  7. Ducabike Ducati 1098 1198 CNC Clutch Cover
    Why not show off the unique open dry clutch with this beautifully crafted clutch cover made by Ducabike in the same home town as Ducati in Bologna, made with aircraft grade aluminium and unique real carbon fibre, specifically designed for your Ducati motorcycle. We also sell full clutch kits including stainless springs, spring caps & pressure plates.
    Fits: All Ducati dry clutch models
    https://conquestracingltd.com/product/ducabike-ducati-1098-1198-cnc-clutch-cover/
  8. wow the conquest website is like soft porn
  9. Ducabike Ducati Multistrada V4 Adjustable Plate Holder
    The Ducabike Ducati Multistrada V4 adjustable plate holder is a direct replacement for OEM, complete with all the small parts, plug and play.
    • Adjustable inclination of the plate and its height.​
    • Adjustable the width of the indicators.​
    • OEM license plate light, turn signals and reflector can be reused.​
    • Perfectly compatible with the stock rear radar.​
    Universal, it is possible to reuse the OEM license plate holder therefore compatible without any modification for all countries and number plates worldwide.
    All products are made in Bologna Italy and designed to complement the aesthetics and performance of your Ducati.
    Fits models:
    Ducati Multistrada V4 / V4S / V4S Sport / V4PP
    https://conquestracingltd.com/product/ducabike-ducati-multistrada-v4-adjustable-plate-holder/
  10. Ducabike Ducati Multistrada V4 Extended Brake Lever Pedal
    Ducabike billet CNC extended brake lever pedal is ideal for road & off-road use, it allows better support on the rear brake control, in addition, the pedal surface has been grooved to offer maximum grip even in the case of mud or rain.
    plug and play, everything supplied for assembly for the awesome Ducati Multistrada V4.
    Fits: Ducati Multistrada V4/S/PP OEM & Ducabike’s RPPIF04 Ralley toe peg
    https://conquestracingltd.com/product/ducabike-ducati-multistrada-v4-extended-brake-lever-pedal/
  11. Ducabike Ducati SuperSport 939 / 950 Sidestand Kickstand Foot Pad
    Designed to provide your Ducati SuperSport 939 / 950 more stability on soft or uneven terrain & help prevent an unwanted fall which may cost you £1000’s.
    Made from solid billet aluminium & available in 4 different lustful hard anodised colours, specifically designed for your Ducati SuperSport 939 / 950.
    Fits Ducati SuperSport 939 / 950
    https://conquestracingltd.com/produ...ersport-939-950-sidestand-kickstand-foot-pad/
  12. The foot extenders are an essential add-on.
  13. Ducabike Ducati Multistrada V2 Paddock Stand Bobbins
    Ducabike’s paddock stand bobbins provide the ease of using a hooked-style paddock stand for your Ducati Multistrada V2.
    Made from solid billet aluminium & hard anodised in several lustful colours.
    Fits: Ducati Multistrada V2/V2S
    https://conquestracingltd.com/product/ducabike-ducati-multistrada-v2-paddock-stand-bobbins/
  14. Ducabike Ducati Multistrada V4/S Adjustable Rider Footpegs
    Ducabike Ducati Multistrada V4/S adjustable rider footpegs are made from billet aluminium with an anodised finish, specifically designed to provide you extra grip and height adjustment +7mm when riding your Ducati.
    They will replace the original rider pegs.
    2 possibilities for height adjustment OEM and + 7mm.
    https://conquestracingltd.com/product/ducabike-ducati-multistrada-v4-s-adjustable-rider-footpegs/
  15. Ducabike Ducati DesertX Fairing Screw Kit
    Swap the boring fairing skews with these stunning Ducabike billet CNC replacements & complement the design of the awesome Ducati DesertX.
    Made from solid billet aluminium & hard anodised in several lustful colours, specifically designed for your Ducati DesertX.
    x7 pieces
    Max torque 3Nm
    Fits: Ducati DesertX
    https://conquestracingltd.com/product/ducabike-ducati-desertx-fairing-screw-kit/
  16. Ducabike Ducati Carbon Fibre Brake Lever Guard Protector
    This is a lever guard that avoids the inevitable due to accidental impact involving the brake lever. In most cases, the collision does not bring serious consequences but is not excluded the possibility of your bike going “ass over tit”!
    Specifically designed for SBK & MotoGP racing.
    This Ducabike Ducati Carbon Fibre Brake Lever Guard Protector protects the lever from accidental knocks.
    Made entirely of carbon twill with autoclave vacuum process, which guarantees resistance and strength at the same time.
    Developed MotoGP experience revealed a superior strength and a complete lack of interference with the driver’s hand in any type of manoeuvre or fall, as it follows a downward trend in the first part and then goes back and finish the front of the levers.
    After several tests have reached flexibility controlled in such a way that in a frontal collision there is a maximum deflection of about 1 cm.
    High-quality product that offers more than a flawless gloss finish, a touch from MotoGP to your bike.
    Fits: All Ducati’s
    https://conquestracingltd.com/product/ducabike-ducati-carbon-fibre-brake-lever-guard-protector/
