Diavel Noisy Front Brake?
Discussion in 'Diavel & XDiavel' started by silvaspeeder, Jun 6, 2025.
  1. Is anyone suffering from squeaky front brakes on the Diavel V4? Ducati say it’s Normal ?!!!!
  2. One common cause is the semi floating disc aren't floating because the bobbins are seized. Easy fix is to use a 5mm bolt and nut to clamp the bobbin and use a battery drill to rotate them. A bit of WD40 helps but meticulous cleaning it off required afterwards. Andy
  3. Copperslip to the back of the pads?
  4. Thanks for the advice. I’ll give it a go.
  5. Yeah, the dealer did this and no joy. It’s a new bike, 650 miles and they’ve even changed discs and pads on a demo bike to try and solve but didn’t work. Apparently Ducati know about the issue but haven’t found a fix. When I emailed customer support they said the noise was normal!! So I asked why ALL the other bikes in the showroom don’t make a noise when free wheeling!
