Oberon rear wheel nut, eek.
Discussion in 'Multistrada' started by steviegasgas, Oct 2, 2012.
  1. I got a teng tool 55mm socket for 30.00 in 1" then a reducer off flee bay 1"" down too 3/4 for 7 quid then a breaker bar for 11.50 total 48.50 quality tool works easy and happy after blitzing an Oberon pile of shite won't get nuts off a squirrel tool job done do ya homework it pays off all that glitters isn't Gary and all that. Contact toolshack in blackburn
  2. Sorry to hear about the shortage of full stops and commas in Bolton at the moment. You're welcome to some of mine. Here you go:
    #22 Pete1950, Oct 28, 2012
  3. Quick question from a noob.
    You need 50mm and 55mm for the rear end of the MTS 12 (55mm for rear wheel removal) and a 28mm for the front end?
  4. I think it's 30mm for the front, as per the 1098, but rears are definitely 50 and 55mm - same as 1098 again!
    Try not to pay more than £20 per socket!
  5. Cheers for that you can tell we are talking about TOOLS
  6. Couldn't care if you are discussing purple monkey bottoms TBH, get some punctuation in there! :upyeah:
    Love, the Grammar Police. :biggrin:
  7. If your strugling to get the nut off, try warming the nut up with some hot water out of the kettle, works a treat in most cases.
  8. We use a 1" dia Snap-on braker bar (called Bertha) with a 3/4" drive and suitable socket to remove the nuts. Tried various alloy sockets, all worked to some degree but most only had a 1/2" drive.
  9. I'm after a tool/socket to remove my front of rear wheel.. Any new options about???
  10. Cheers, what size is the front 1 22mm??
  11. make sure you have a drive with 3/4" drive. Else you will also need a 1/2" to 3/4" or a 1/4" to 3/4" adapter.
  12. Front is 30mm. There's no 50mm on the back....both wheel nut and sprocket carrier are 55mm
  13. Thanks.. Glad to know there's a few reasonable priced options
  14. Cheers Derek, looks good value for money. Just ordered 1... Hope it would take to long to turn up.. Thanks
  15. Mine took about fortnight and I didn't have to pay duty on it :)
