Oil Filter Not Screwing
Discussion in 'Technical Help' started by Cream_Revenge, Mar 13, 2016.
  1. to be fair, I think the OP bought the bike with the cheap filter already on it
  2. Yes, came with cheap filter, and pliers lasted a good 15 years.
  3. that's the second version lol
    the first had 6mm bolts and they sheared because the filter was that tight
    so second version is a bit more substantial
    wasn't going to let a bloody filter win hah hah
    and I always have it in case
  4. It was meant to be a joke.......
    When I first got my SS, I removed the stuck filter with a pair of screwdrivers and a ring spannner..........awkward, but off it came.
    And then I fitted K&N.
  5. K&N delivered this morning :upyeah:
  6. Not American are you?
    Snacks of American engineering that does...
    Was the filter that stuck, stuck due to poor quality or poor fitting though?
  7. Who knows..........It wasn't an OEM one and if it was stuck, who can tell if it was overtight or not?
    But....tell you what........I remember that after the stuck one; I did fit a new OEM one before I switched to K&N.........
    ........I fitted it all nicely, with a wipe of oil on the seal as per usual...............on a very hot summer day (even hotter in the workshop)..........All OK throughout the rest of the year until Winter.........and then it was very cold..............
    ..........started the bike and oil was peeing out of the filter immediately............turned it a bit tighter and it stopped for a while, but then I guess once it had got through, it just kept on dripping quite a lot............I now change filters when the weather isn't too hot.
  8. Just taken delivery of 4 litres of fully synth Motul 7100 plus a HiFlo filter for 40 quid from M&P. Seems like a pretty good deal if Hi Flo filters are any good.
    Anyone know??
  9. have been accused of over engineering things
    but just used odd scraps at work to make that
  10. Have done a little research and Hi Flo filters would appear to be the same as K&N but without the nut.
  11. Serious bit of kit that... :)
  12. Who sells the Mahle filters?
  13. I get mine from Opie Oils.
    Steve
  14. That appears to be the same code as Opie and a better price.
    I haven't purchased any for a couple of years now as I bought three oil and three fuel filters last time.
    Steve
  15. Cheapskates......
    You will fork out ££ss for a load of carbon shite and can't be bothered to clean your battery and earth lead connections........
    .............but ....how often does anyone need to fit an oil filter to save £5.00 each time?
    Bunch of twits......:astonished:
  16. Yes, I'm sure that's the right one, the code and the measurements are right even if the proportions of the canister in the pic are wrong.
    Annoyingly, the shipping costs from this company are actually more than the cost of the unit itself, as they put it in the over 0.7 kilo bracket. So the final costs end up very similar.
  17. ... or the following oil filter codes will fit:
    AC Delco AC137, SW, X4030E, X4106E, X4A, X5,
    Alco SP817, SP833, SP857,
    AP Lockheed AP1014, LK1014,
    Asahi AMC NO229,
    Baldwin B7292,
    Bosch 0451103010, 0451103015, 0451103015850, 0451103020, 0451103042, 0451103139, 451103139, 9181474010, 9450732004, 9457281210, 9457281290, BOF1010, BOF3137, P3139,
    Champion H101,
    Citroen 5427744, 5427744T, 5436642, 5475796, 5487068, 5491083, 75491083, 75518393, AM222105, AM222128A, AM2226A, AM223101A, AM223102A, AM223104A, AM223128,
    Coopers Fiaam GUD FT4347A, FT4554, FT4654, FT4847, Z102,
    Crosland 631,
    Delphi Lucas CAV FX0011, FX0012, FX0023, G369,
    Ducati 090549960, 65149960, 90549960,
    Ford 1527957, 5002394, 5002452, 5002731, 5002732, 5004927, 5006947, 5007367, 5012038, 5013144, A700X6714BA, A720X6714EA, A760x6714AA, A760x6714MA, A760x6714NA, A780x6714FA, A800x6714DA, A800x6714MA, A830x6714ARA,
    Forgeville PH2864,
    Fram PH2839, PH2839-1, PH2847A, PH2864A, PH2873, PH2873A, PH4868,
    Greyfriars 937S,
    Harley Davidson 6381080,
    Hengst H91W,
    In-Line Filters FFRPH2839, FFR-PH2839,
    Mahle Knecht AW31, AW65, OC10, OC12, OC5,
    Mann 6740258526, 6740259516, MW713, W712/11, W712/7, W712/9, W71211, W7127, W7129,
    Motaquip VFL111, VFL120, VFL188, VFL209,
    Motorcraft EFL111, EFL112, EFL121, EFL47, EFL79,
    Permatic ELH4106,
    Peugeot 110963, 110973, 1109-73, 110974, 110979, 1109-79,
    Powertrain PMFL25,
    Purflux 6120605870, 6121743820, LS131, LS187, LS197,
    Purolator Facet AW13, FC103, FC601, FC79, FC99, L17601, PC203,
    Quinton Hazell QOF2094,
    Savara 92806211, 92812111, 92812911, SO062, SO121, SO129,
    Soparis CV341, CV376, CV377,
    Talbot 0012851491, 0016339700, 0061501500, 1285149, 12851491, 29932M, 41023M, E29932, E41023,
    Tecafilters 9350623, 9350624, 9350659, H0623, H0624, H0659,
    Tecnocar R434, R72,
    TJ Tecalemit FB2094,
    UFI Sofima 23.105.00, 23.142.00, 23.149.00, 2310500, 2314200, 2314900, S2100R, S3700R,
    Unipart GFE11, GFE201, GFE212,
    Vauxhall GM 7984149, 7984608, 9975244,
    Wipac CA108, CA111,
    Wix 320P, 51352, WL7101,
    Woodgate WGL9032
  18. Have changed the oil for lovely cherry red Motul 7100 fully synth.
    At least it's easy to see the level in the sight glass now :)
    The old filter came out nicely with a strap tool from Lidls and I was able to prime the system by turning the engine over with the stand down so it wouldn't fire.
    No leaks, so I'm a happy bunny:)
    #60 Old rider, Mar 17, 2016
