Quick-shifter options
Discussion in 'Technical Help' started by deleteduser211220, Feb 12, 2014.
  1. Cool - thanks. That looks like it would plug in to the ignition circuit? That plus the lever is only £245. Pretty good value...
  2. I'll have to ask them, as my set-up has the ducati QS integrated into the standard evo corse se loom.
  3. As i use the microtec M197 ecu that lever is plug and play into my ecu…which has all the adjustments required for it. (its also the lever that is badged by nemesis and microtec themselves…with a ducati ecu you would need the bit of loom….
  4. Even though i've taken off the ducati qs lever?
