Radial Clutch Master Cylinder Conversion 93 750ss
Discussion in 'Supersport (1974-2007)' started by TBay, May 3, 2025.
  1. The incredibly heavy clutch on my 750SS was spoiling my enjoyment of the bike after only a few miles. I looked at various options, including machining a sleeve to fit the existing master cylinder to improve the ratio. Someone mentioned a radial master cylinder being more efficient so I started looking at possible ones that might fit. Ideally with a 12mm bore the same as the existing one. Long story short, they are pretty much unobtainium. I saw 14mm ones and after a lot of reading and comparing stats I thought it was worth a chance. Best (sort of calculated) guess was that it would 20-40% lighter pull. One was ordered and fitted. Weather then was either terrible or I was working, or I was out on the MTS with mates so it’s been a few weeks……...
    So today I took it out for a test run and am impressed with the results. It certainly isn’t as light as the MTS but is very much noticeably lighter than it was. I can even find neutral at lights now, a previously unknown luxury. I can’t see the neutral light so will need to investigate LED bulbs, 1st problems eh? Previously my wrist tendons were painful after less than 10 miles and town riding was awful. I picked a purposefully crap route today and after about an hour my wrist was just starting to complain. I would guess that would equate to at least a couple of hours on a good route.
    Overall a very worthwhile bit of work for a grand total of less than £50.
  2. Tbay,
    Intresting, good report. Have you got the part number or info on where to buy.
    Cheers Gaz
  3. I bought an Adelin brand one from China. Mostly to test the theory but saying that the quality is suprisingly good. I stripped it and checked the tolerances and it’s bang on. Seals looked to be the same as brembo, but would need a set from each to confirm. They are widely available in a range of sizes from 14-18mm, but 14mm are the least common.
