My 999 battery was low and it only managed to turn the engine over a few times. I connected an Optimate for a few minutes and then had another go. Not enough oomph from the battery still to start the bike. When I turned the ignition off there was a faint buzzing noise coming from the rev counter area. After turning on and off a couple more times the noise stopped. Anyone know what causes the noise (low battery charge??)and if it is anything to worry about. I have had the bike since new in 2005 and it hasn't done it before. Thanks.
I've had a low buzzing/clicking sound from the rev counter area too, when my battery has been low. I don't worry about it : o ) Someone will be along to explain shortly.
If you do remove the clocks, be careful not to lose one of the grommets into the subframe when re-attaching! A little bit of lube helps. That said, the buzzing is normal if your battery is low.
New battery plus a cable kit from @Exige recommended. Trying to start a reluctant Ducati will lead to a knackered sprag clutch, which will be s right pain to fix.
